Central Motorsport ECU
As u may see from the for sale section, just bought this off DaveC.
Just wanted to know if anybody had some info on this ecu.
Can i now up my boost with it?
Will it make any difference to my car?
Not heard of that, I have one from Central20 Racing, which from the code looks pretty wild !
Think they're the same. The timing maps they use are very aggressive. I'd keep the boost to about 13psi on it, but listen for det. The mid range is where they really bump the timing up so keep a close ear out.
maybe better refrain from fitting it as my car sometime looses boost on stock ecu
Yep it is a Central 20 ecu and since fitting it my car hasnt gone into saftey boost once. this includes the 400mile round trip to billing.
So if i was fitting boost jets are 1 mil ones ok?
Start with 1.2mm and get a known working aftermarket boost guage to see what boost the 1.2mm jets give you (DONT rely on the stock guage!) then try 1mm ones if you can go higher.
Then booooooooooooost away, the difference is mental :hyper:
who are central20 and has anyone got a number for them as my car was all fitted out with there bits :confused:
Yes see what you mean :( :confused: :confused:
http://www.central20.co.jp/
Now who can speak japa****inese? :D
I have a chip with a Central20 auto map if anyone is interested ....
Hi Andy
Confused there was I thread about auto to manual ecu's last week
would this go into a uk tt manual?
and how much would you be wanting for it?
atb
paul
Hi Andy
atb
paul
Yes, it should work in a manual TT car. Not sure I really want anything for it, I can email you the code if you want. However, should you want you're ECU socketting then I should be able to help out ....
Oops sorry andy missed the reply??
cheers andy I'll bear it in mind as I'm not sure where I want to go yet m8
Must get the body work finished.................I keep telling myself
