Stalling when slowing down ?
- Replies 40
- Views 2.8k
- Created
- Last Reply
RobH 7 posts
KennyZ 3 posts
EvoluZion3 2 posts
Jay 2 posts
Hi all,
Got a bit of a problem with the revs dropping below idle speed when slowing down - especially from 50mph+ speeds. It sometimes picks up again but often stalls (most embarrassing!). I can often avoid the problem by changing down through the box as I'm slowing down.
This problem is definately worse since fitting Blitz BOVs on hardpipes. I'm pretty sure I've ruled ouut any chance of a leak. I've capped the points on the intake where the original recircs connected, capped the outlets from the recircs and connected my vacuum lines to the recirc vac lines. I've left the recirc vacuum connectors open - do these also need capping?? The BOVs seem to work ok but I'm not sure if they need adjusting (they're not hissing at idle) - second hand units so who knows what pressure they're set to!?!
I've used the shortest lengths of vacuum hose I could get away with without any kinks but I'm wondering if the additional hosing is a bit excessive along with a good couple of yards for the boost controller as well. Must be something vacuum related as use of brakes and clutch seems to make it worse/more likely to stall.
Car idles perfectly when stationary
Any suggestions would be greatly appreciated.
Best regards,
RobH
