Boost Jets
Guys do they go in these lines?
Passenger side goes into a hexaganal bolt/pipe on plenum
Driver side goes into ballance bar
Both go under hard pipes.
silly question. if they do go in these is there any point in takeing the hard pipe off to get to the other end.
my way of thinking the hole restricts the system no matter where it is or am i pissed?
http://zhome.com/ZCMnL/PICS/boostJets/boostJets.html
have you had a look at this link
i dont think its those pipes
you cant even see the nearside one without removing big pipe
the pipes come off easy put jets in mine inabout 30mins
steve
looking at your picture again it could be thouse pipes
are you thinking off cutting the pipes and jubileeing them together
steve
There are small hoses which lead off the inner boiost hoses (i.e. the ones that connect to the thorttle boddies).
It may be an idea to do the squuze test first to make sure you haven't already got jets in there
lol I know the drivers side is the right one. not sure about the other side though. just looking at the pipes there, there is only one that is remotly simmilar heading toward the intercooler
dave, if you remove the two intake pipes to the throttle body you will see a small 6-8 mil hose about 3 inches of the way down those are the pipes you want, you will be able to tell because they have a second cover on them almost like a double pipe , thats if there original. if you follow the pipes they will both lead to the actuators on the tubs , if you have the wrong one these will be vacumm hoses that go to the plen
Ryan
