im curious to see who rates what mods for the z.... so if you feel a mod is that essential for the z please put it in here............... or if you have a seriously modded z then put your top mods on here
LET THE MODDING BEGIN!!!!!
Filter
Zorst
Boost upgrade
Chip
Clutch Flywheel
R33 Brakes
Stillen Anti Roll Bars
Bigger radiator
Bigger Oil Cooler
Lightened Pulleys
HICAS removal
HICAS removal
should never have put it on in the 1st place.
"i 2nd that
Quote:
Originally Posted by grahar81
HICAS removal
should never have put it on in the 1st place."
ive had no problems so far. anything i should know about???
"i 2nd that
HICAS removal
Nope. Just some people doing like it. When it starts needing replacment parts it starts to get expensive. :(
Plus many people who have removed it say the car handles better with out it.
EVERYTHING WORKING PROPERLY.
Which implies:
No boost leaks
No coolant leaks
No fuel leaks or other fuelling problems
Good coil pack and injector connectors
Good temp sensor harness
Adjusted TPS
Therefore number one mod is Smithy's hard pipes for induction and fuel, plus all the vac hoses!
Number two mod is Pete's kit to ensure decent earth.
Then you can think about everything else...
Good Tyres
Better Brakes
Remove Hicas
Ploy bush kit
New springs and shocks
Better Rad
Even a totally standard TT will cook the brakes.
In that order. A good standard car will be a real pleasure to drive with the above. All the other Thousands of pounds we spend is all personal taste.
Shares in Optimax :D
Bushes and arms went south and replaced them, still had Hicas trouble.
So, replaced teh Hicas with a Stillen Unit.
Total transformed how the car drives. No move jumping out on you, no more feeling is that the rear steering or is that the reer sliding. No move heart punding moments.
