boost jets
Hi all,
Just a quick question, the instructions say just to puch the Jets in the two small hose's.
Do I have to clamp the jet in the pipe, so that it does not get sucked in somewhere though the hose? :confused:
If the outer diameter of the jets is too small to fit snugly in the pipe, one solution is to cut the pipe and use 2 jubilee clips to clamp the boost jet in between.
This means you can get them out easily if you need to.
Its a tight fit, but just did not know if they had to clamped down. As I did not want anything getting sucked in. :)
Have just got these, they any good. no idea of the diam :rolleyes:
