Does this sound right?
as per previous posts im losing boost - 5psi and with boost controller set high I can get to 10psi
ย
However even though I used to get 14.5psi my 10psi feels extremely quick. Pulling away in 1st, lift up clutch fully then flooring it results in wheels spinning and screeching, quick change to second and lots more mad screeching and spinning. Have I just forgotten how quick my car was as Ive only been running 5 psi.
Just a thought,have you recently fitted an aftermarket boost gauge and then found this prob.
ย
Tony
no mate
Aftermarket Boost guage was fitted when I got the car
Ok mate,just wonderd if the vac line to the gauge may of been restricted somewhere,what does boost controller say pressure wise compard to the gauge,can you hear any hissing type noise when you on boost,remember once having same and the small tube from rear left hand side balance bar had a split in it but could not see it as it was underside,.
ย
Tony
aftermarket Boost guage reads 5psi
Boost controller reads .5
ย
I think controller is BAR
I'll have a proper look tonight
ย
cheers
