Engine nearly finished
following in kirbz footsteps :duffer:
Engine is just about finished just the sump and the plen to put back on with any luck it should be back in the car this weekend.
The engine has been totally rebuilt using wiesco pistons I have also put new valves, springs, lifters and manual Cams in along with every oil seal gasket and rubber hose that the car has
The crank has been balanced , surprisingly enough even the under drive pulley was not properly balanced from the factory
The heads were off by about 2 thou so these have been matched so that they are equal the engineering shop also did a 3 way valve angle job on the valve seats
Here are so pics of the progress so far
  • Replies 48
  • Views 1.7k
Nice one mate - that was quick too :bow: Cant wait to go out in it ;):cool:
cheers Pete
3 weeks , would have been one if the engineering shop got there backside in gear a little quicker
have you or any one use solid valve lifters, ive got a noisey tappet on mine and it seems to be a bit of a fault on the 300's, any one got pro's or cons for them???
Must be great to know you've done it all properly
Time will tell mate
JD'S-Z not used solid lifters , I think but don't quote me these are only used when you use high lift cams for fairly big power
Nice one ryan bet try not having your zed for 8 months like me, just hearing her fire up today made me wanna cry with joy ;)
Mike
nice one, seems everybody has there engines out of their cars at the mo
Yeah tell me about it :rolleyes:
smithy
Mike
Look out for severe flooding :cry: when mine fires up in the next 2 weeks after 17 months :rofl:
:shock:
:shock:
LOL :tongue:
Nice one Ryan :cool: hope it all goes ok on start up. :)
Tony
ps,my Z is on its 4th engine since imported,is this a record on here :rolleyes: :D
Im nearly there to :D
Just waiting for the exahust flanges to get back because the studs are getting replaced and need to be machined out :mad:
:duffer: Good luck to all you guys..mine's only been away 7 weeks now and i cant feel as bad as you lot not having her for months...
Hope all goes well .....on start up people:D
Matt
who needs companies like SE when you have people that are willing to do it themselves :dance: :tongue: , nice on Stu :bow:
Throttle bodies look quite small really dont they :)
The throttle bodies are off ;)
ROFL :rofl: Pete= specsavers ROFL :tongue:
All depends on what you want at the end of the day,some have no choice as funds are low:( Some want serious conversions.some like yourself as so greedy and tight that is breaks your heart to part with a £2 coin :tongue:
Iain those that can do those that can't pay someone who can , I must admit you do seem like the paying sort :tongue:
Looks good mate, those heads came up superb, give me a shout if you want help sticking it back in the car on Sunday.
Those that can afford the choice go and have fun while some other poor b4stard struggles.
Those that carn't afford winge on about how its a labour of love etc but, I know, because I've spent those weekends removing my knuckles in the cold, dropping that washer down the cam belt channel into the sump just as your about to put the head back on.
No thanks Guys your welcome to it I'd rather work harder at what I'm good at and earn the money. You have my knowing respect but there's nothing honnerable in DIY. Just think the money you've saved. Her in draws will expect those saving every time. Rod and Back spring to mind
This is where the phrase check book mechanic comes from ;D or Skyline Owner!
No this is where the phrase consider all consequences before volunteering comes from :D :D :D
Very true;)
