Engine nearly finished
- Replies 48
- Views 2.2k
- Created
- Last Reply
MAC 1 5 posts
pete shrimp 4 posts
Paul C 3 posts
markzx 3 posts
following in kirbz footsteps :duffer:
Engine is just about finished just the sump and the plen to put back on with any luck it should be back in the car this weekend.
The engine has been totally rebuilt using wiesco pistons I have also put new valves, springs, lifters and manual Cams in along with every oil seal gasket and rubber hose that the car has
The crank has been balanced , surprisingly enough even the under drive pulley was not properly balanced from the factory
The heads were off by about 2 thou so these have been matched so that they are equal the engineering shop also did a 3 way valve angle job on the valve seats
Here are so pics of the progress so far
