Plenum Help Needed
I'm getting ready to swap Plenums from my old non polished one to the polished and chromed one I have just had!! :D
I want to use stainless steel bolts but I can only get hold of 'metric' ones from work (the look I want!) which ones of the holes on the plenum can I tap out to accept metric (same size but different thread) without chuffing things up!!
i.e. which ones have to have the old bolts in, and which ones can I tap out to metric? Or can I do them all without any problem?
I've attached a pic if you want to circle the okay to do holes that would be great, cheers!! :D
Matty.
They are???
I tried a couple and they turned a bit and stopped, felt like the thread was wrong...
I'll go have a try...
Matty.
lol, maybe you have the wrong pitch on your new bolts! hold together the old bolt & the new - see if the threads fit together
Matty
here is were the fun and games start best of luck ,I found this a big pain in the arse but is well worth the pain ;)
Matty.
I changed every blinging bolt visable on my engine bay for stainless steel :dance: :dance: :dance: Are you going to be at Thoresby Show Matty.If so I can give you the secret of BLING. As you are now a true follower :cool:
I was talking last night to Chunk about it, I think I'll be going and then I can pull up some rug, sit and listen to all the secrets of bling.....
:bow:
:D
Matty.
great looking manifold! is that chromed or polished?
get youre self a thread gauge works like a feeler gauge put it up against thread and find one that fits exactly then that will tell you thread type, i e 0.75mm, 1.0mm or 1.25mm these are the most commen!!!
