hey guys!
looking to set my controller up,
does any one have the formula for convertiny KG/CM to PSI!
looking to get around 12-14 psi to start with!
also to set throttle sensor do these run;
throttle closed 0v
open 3v-5v
OR closed 3v-5v
open 0v
thanks guys! steven
PSI Kg/cm Bar
5 0.35 0.34
6 0.42 0.41
7 0.49 0.48
8 0.56 0.55
9 0.63 0.62
10 0.70 0.69
11 0.77 0.76
12 0.84 0.83
13 0.91 0.90
14 0.98 0.97
15 1.05 1.03
16 1.13 1.10
17 1.20 1.17
18 1.27 1.24
19 1.34 1.31
20 1.41 1.38
or you can download this program :) http://www.joshmadison.com/software/convert/
Vijay
throttle closed 0v
open 3v-5v
OR closed 3v-5v
open 0v
Our TPS is allegedly 0.4v closed and 4v open, so I'd go for the first option!
Think you can ask the AVC to display the throttle voltage anyway, so you could always check that way.
cheers guys very helpful as usual! :dance:
still havent decided what boost to run yet, if only i had done fuel injectors too!!!!!!!
worried about running too lean top end really dont want to melt it!!! :rolleyes:
