Baggins- Follow on advice needed please
Hi Ryan
Thanks for your help today- it was much appreciated. Just trying to remember what we talked about regarding the knock sensor.
So we found out that I have a faulty knock/detonation sensor (I take it that its the same thing). And that a wire was cut/snapped on the knock det sensor connector. I have patched that cable back up, but still get error 34.
Managed to get it back to 55- all clear then went round the block and it went back to 34 again.
The question really is how do I find out if this is caused by a faulty sensor or whether it is suffering from det. If it is suffering from det, then I guess I need to address that problem. It could also be wiring problem as it is all in bad nick but as far as I can see, there are no other breaks in the wires.
There was talk today of using a resistor to get round the problem, but I understand there is a possible risk when doing this.
So, saying its worse case- have to have the engine out to do the sensor, where's the best place to take it to? Bearing in mind, while its out, I'll have cambelt, pump, hoses etc done as well. + the loads of other bits that I know need doing.
AL :D
Hi Ryan
AL :D
No worries AL
options are
Resistor trick
top part of the engine pull to replace the sensor itself
re-look at the connector loom might be something simple
Ryan
No worries AL
options are
Resistor trick
Ryan
You can also drop the gearbox and replace the sensor that way, but the downside is you need small hands, upside is you dont need to strip half the engine.
Just my 2p worth
No worries AL
options are
Resistor trick
Ryan
Short and sweet- I guess I'd already answered my own questions
Think I'll chuck in the resistor for the mo until I get the cash together for the major work.
Any ideas where I can get the resistor? Is it specialised or can I just get it from somewhere like maplins or RS?
Just my 2p worth
Thanks for the tip. Gearbox is on my list of things to do as well so could be handy to do it then.
...and me got small hands
PM me your address Al and I will send you one ,
Thanks Ryan- me owes ya a drink or two now
