Good article for zx problem solving/upgrades!
So what it's saying is that when doing the boost test you can only pressurise the system to 5psi? Even though the stock system is 9psi?
Ivan :confused:
yes, cause youre pressurising the whole intake from the MAS connector back. the intake is only pressurised from the outlet side of the turbo onwards under normal running ;)
