High Tickover
I have just finishing transferring my trusty old engine to my new Z and the tickover is approx 1500 rpm +/- 200 rpm. The only difference is that I've fitted an RPS lightweight flywheel which is 11lbs instead of the stock 22lbs unit - could this be the reason? anyone else had this?
Dave.
Thanks Paul - I've sorted it now - I'd connected the RH wastegate control pipe to the wrong pipe at the front where the intercooler (to/from) pipes are! The giveaway was when I took it for a run and there was no boost either!
Dave.
