nzr power supply for pc
Just stripping out the power supply for a pc as it has blown up but it has a 200w one in it which are hard to get, can i fit any other one without probs like 350w?
Higher capacity PSU won't cause a problem but check the form factor of your case. It may be a Micro ATX (small case) in which case you need a compatible size PSU. Most parts suppliers should be able to advise. Let me know if you need any help though...
Steve :)
'93 UK TT Manual
What system are you running? Some systems new need at least 350Watt.
Don't know what the system is as its not mine and it obviously doesn't work yet. Some sort of AMD.
