Carbon canister removal
Do the pipes need to be blocked off when you remove it?
Where do they go and what do they do?
Chris,
There is one small line that goes to the LHS throttle body via a hardline, blank it. One 1/4" that goes to the balance bar, back LHS, blank it. One line goes into the front crossmember via a hardpipe (think it's off the bottom of the can), unbolt it from the crossmember and remove the non-return valve, connect the vent line from the tank to this.
All the other ones can just be disconnected (I think there's a 1/2" that vents into the main chassis rail).
