Just had the plenum off to sort the problem out checked all the hoses,plugs and gaskets and the forking thing still will not tick over it just give up :xxx: :xxx: :xxx: Who the fork can fix this in the north west :bow: because I've about had it :mad: :mad:
everthing was ok before I took the plenum off to change it for a polished one
it will run with a bit more rev but will not tick over
Is the tps at the correct voltage ?.
ย
Have you got an air leak somewhere ?. Any obvious hissing ?.
ย
Probably point the obvious but it's all I can think of at the moment.
