RichardS ·
Hello everyone,
i´m looking for new wheels for my Z. Personaly I like the AVS model 5´s.
But will these fit the car. I´ve done some research but I like to be sure on this one.
The front is 18×8J - pcd 114.3 - offset 45, and the rear wheels will be 18×9J pcd 114.3 - offset 35.
Well let me know, thanx.
