Air Con Siezed?
Driving to work this morning with the front demister operating all of a sudden the car gave out a massive squeal and stalled.....
A real 50p - 20p moment :shock: - the pounds fell before my eyes!!
Restarted only for the squeal to return and a smell of burning rubber. However, turning off the A/C (econ mode) and everything was fine again. A/C on and engine goes off (when idling) :rolleyes:
Is it fair to say the A/C compressor has siezed?
Are these easy enough for a competent to replace?
Are they better to buy new or second-hand (AndyZ?) If I buy new, should I get one for 134a (p/n 92600-48P00/1) or one for the older gas (-30P01/5). Would I need a new receiver also?
Is there anything else I should be concerned about? I plan to remove the connector for the high pressure switch on the receiver, so I can still have demist without A/C use.
Cheers for your ideas :duffer:
St
Compressor has seized. As far as replacing, not too bad a job (just the rear fixing bolt for the compressor is a PITA to get to). In order to stop the clutch engaging on the compressor, there is a single wire coming from the top front of the housing, follow this to the connector and disconnect - this will stop the compressor clutch engaging ;)
Nowt wrong with the belt (aside from a little heated?)
Cheers Andy (as usual!) - I'll disconnect that until I get around to having the compressor done and regassed.....maybe next year :slap:
