My Zed just seems slow, Baggins has also driven it and agrees, I'm trying to work out why.
The car is a '93 UK Manwell Zed, with a Mongoose Exhaust, Cat's still in place, JWT type Induction kit, ASH Map Chip, Greddy Profec Boost controller, Greddy Intercoolers. I've had the car up to 15.5psi with not a hint of Dett, the car doesn't smoke, however the car does run very hot, after Baggins stuck the conzult on it (no error codes) it was running at about 100 degrees! which is apparently fooking hot. The car has 115K miles on it and is due a Cam-Belt change any time now. The car seems to struggle higher up the Rev range i.e. I would expect the revs to rise faster from 5-7K then from 3-5K as the Boost is at full pressure.
Note: I've had a problem with water getting into the MAF (MAF has been replaced, runs sweet) but the JWT type air filter has been SOAKED on quite a few occasions, could it be fooked and need replacing?
Has anyone any Idea's as to what the problem could be? or what I could do to help fault find the problem?
Thanks in advance.
