- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Sorry to bother you big man, but you were particularly helpful when I had the 5 cylinder issues and you happened to mention something re: valves.
Basically, I cleaned the connector on the injector, I didn't remove all the green but I though it would be sufficient to at least get a contact. I checked to hear for the clicking with the screwdriver trick and it was definitely A-OK. But still not firing on number 5.
Anyway went up to the factors and purchased some STP injector cleaner, dumped it in the tank with a full tank of Optimax and went for about a 30 mile run - fairly hard.
Came home and it was sweet as a nut, I let it idle for a bit and it never missed a beat. Turned her on again later on that day and back to the 5 cylinder problem.
Took her out again today, another wee blast, same thing, minty! 1 hour later 5 cylinders!!!
You had mentioned something about a faulty valve - is that likely seeing it is fine at top temperature but shitty when colder? Could it just be a blocked injector? Or perhaps I haven't removed enough of the green muck in the connector!?
I know this isn't easy to work out when you're about 400 miles away but any guidance you can offer would be most appreciated.
Pete
