central locking u/s
my central locking isnt working on my zed :( does anyone know if there is a fuse ,relay ,or control unit that could be at fault
thanks
Hi mate,
mine didn't work when I got it either :( Then neither did the courtesy light.....
Turned out to be a bad earth connection. My mechanic found and replaced it in 10 minutes.....
Good luck
Richard :)
ok had another look at this and the courtesy light is working ok so deffo not fuse
ive removed the drivers door card and found a four wire loom going to the lock actuator in the door (the integral one conected to the latch) i have a 12 volt feed and an earth on two of the wires so pressume the other two are signal wires to operate the passenger lock, these wires do nothing when lock/unlocking drivers door so i think the latch mechanizm is at fault
could anyone confirm this?
I had this
there is a a brass block that connects the central locking to the lock mechanism one of the allen screws had come adrift disconnecting the two
what a bitch to do
good luck if it is this
