im about to fit a new viscous fan,to do this i need to remove the shroud surrounding the fan , ive removed the upper screw below the rad cap, the one on the left is directly below the upper water hose!im doing a collant change anyway so that can come off.Do u need to be under the car to sepparate the upper shroud from the lower,i know its a dickhead of a question but i think its clipped together hope u can help cheers greg :)
Yeah, the lower half of the fan shroud comes off so you can lift it out. There maybe a screw or 2 down there too.
cheers mate can u get the lower half out from inside the engine bay or do u need to be under the car doh :slap:
need to get underneath really. Remove the splash guard, then the bottom pulls away in the middle then a tug down from either side while pressing some tabs will sort you out.
cheers for that mate il have to invest in a trolley jack as my car sits on the road basically :cool:
You won't get a trolley jack under there mate it's too low. Just drive it up onto a couple of blocks of 2x4 and you should get enough clearance. I can and I'm a fat Ba$tard :rofl:.
I take it your package arrived then ?
How ignorant of me sorry bud yeh the part came last week much appreciated for that going to do it tommorow along with 10 other things u now what its like!! regards greg ;)
