My new front
Decided to go with Nelsons theory when deciding on which front end to go for. What do you guys recon to this?
Reason for this is:
I like being able to see my engine though :D
Interesting way of obtaining less mass! I presume rust weighs less then steel?
No its just you :tongue:
Actually I thought that too but the alignment is fine - must just be the angle the pic was taken at.... :)
The propellor blade on the front should give you a bit of extra power too :rofl:
Found this, thought ya might like it.....
Had to do that to mine last year Andy. Looked a right mess, but all sorted now. I did however have the luxury of a garage!!!!!!
Keep up the good work matey.
Nick
:cool:
I pretend to work, they pretend to pay me!
LOL Cheers Nick - not too bad a job when you just CHOP (yes CHOP :D) the aircon out :D With the power figures I'm gonna be looking at, I need all the extra cooling I can get for the engine so it was an easy decision really :)
I want a garage :cry: LOL
LMFFFFAO :D:D:D Where the hell did you find that? :D
http://www.bangedup dot com warning though...there's some really really nasty stuff on there. :x: :eek: :cool: :)
One serious point from all this though.
You guys should check out this item on your car - the corrosion was caused by Nissan kindly fitting a piece of foam between the radiator and the aircon condensor. This holds any water right against the cross member and destroys it. Most cars will not fail an MOT on this though as it is hidden by the engine splash guard. I run without the guard so it was spotted by the tester - however they are not allowed to remove any parts to check for an MOT... This is a major load bearing part of the car and if allowed to rust like this could be dangerous...
Just a thought.... :)
CheerZ,
Andy
Having said that, I've just found a close up mpeg of a lovely little darling doing the 'golf-ball' trick! ;) :) ;)...POW! POW! POW!! :rofl: :rofl: :rofl:
