TPS and Autobox
Anyone know what the TPS voltage on Pins 34 and 35 of the Autobox ECU should be? as i'm getting the same voltage everywhere BUT the Autobox ECU pins for the TPS. so its 0.4V at the TPS 0.4V at the ECU but only 0.1V at the Autobox ECU unless i unplug the ECU then its the correct voltage.
Dose that sound like my ECU fooked?
Any info on this yet??
Ok,have done some reading on this,but best to look at this,
http://www.300zx.co.uk/cgi-bin/manual.cgi?list=at&dir=&config=&refresh=&slide=58&cycle=off&scale=0&design=default&total=194
"A" when ign on should read battery voltage,when ign off should read 1v or less.
TPS check as follows,
http://www.300zx.co.uk/cgi-bin/manual.cgi?list=at&dir=&config=&refresh=&slide=53&cycle=off&scale=0&design=default&total=194
Hope this helps Tony :)
Cheers m8, thats what i've done and i'm getting a reading thats much lower then it says it should be, but if i unplug the autobox ECU i get the correct reading! anyone think its the autobox ECU thats fooked?
