newbie!!! few probs looking for help!
Hi everyone! i got a f reg auto tt. Now the gear seems to be holding for too long sometimes upto 5k then throws the next gear in so that your neck almost snapps! when accelerating hard this doesnt happen!
The other problem is when accelerating from 0 i get a funny shudder for about 1/2 seconds then all is well!
So please any advice will help lots and bare in mind im new to this motor so details of checking levels etc need explaining! yes im a bit dumb too!
Fonzy :dance:
Welcome Fonzy,
£20 to join the club buddy, but heres 1 freebie:D
Your 1st problem sounds like to gearbox ECU, Check out AndyZ in the traders section
2nd maybe Prop bearing thingy........the boys who know will answer soon :bow:
All the best
Rich
or your TPS needs adjusting.
Vijay
Like i said bud! im a first time muppet! TPS??????????
Thortle position sensor, little black box on the right side of the intake plenum. If its an import make sure you got the switches and stuff for the autobox set in the positions you want to drive in.
Right! that great fellas! cheers!
So just to check! the sticky gear things could be the ecu needs resetting or the TPS
In which case are both the things easy to do??
MAny thanks once again!
:xxx:
:xxx:
Errrrm, To reset the ECU's disconnect the battery for about half hour... I think :rolleyes: The TPS is a bit more complicated, youll need a multimeter thingy to do it right. Do a search for TPS.
The ECU reset is easy and best to do first. Remove the negative battery terminal and leave it off for at least an hour, see what the car is like after that.
Adjusting the TPS is trickier, you need a multimeter to check the voltage across two of the pins, or someone nice with a ConZult diagnostic tool could check and adjust it for you if you put a shout out for free beers ;)
Start with the ECU reset though :) And check (if its an import) that the Power/Hold rocker switch by the gear shifter is in the middle position.
Pete
Pete
It is an import and the power hold switch is in the correct position! and there is beers involved for anyone wanting to look here over with a multmeter thingy! i am based in camberely surrey! and would love to meet up with someone with knowledge within 25 miles or so! beers definately inlvolved :duffer:
I've got a prob with my autobox too, and am in surrey, feel free to mail me if you need any help mate as i have a multimeter :D
redstarinc@hotmail.com
