Any Info on this Lymon?
By fitting larger turbo's on my Z, I may have to move one of the engine mounts?
  • Replies 33
  • Views 979
yeah I had to chop some of my new nismo mounts up to get the turbo to fit :cry:
erm no, just makes sure you only take the bare minumum off though so not to weaken them.
Will try to take a pic tonight if I remember.
CheerZ Jezz;) All I want is my engine falling out,that would be good:D
Which turbo's does this apply to?
Will I have this problem with my tiny T28's? LOL
No, not just with TD06's.
with most turbos that have a T3 or larger compressor housing you'll have to modify the mounts.
-Eric
here ye go. :)
So what about my T28's?! lol
If you have T28's with a T3 compressor housing you can probably best have a dremel ready :D
S14 T28's have T3 0.6 A/R compressor housings.
you'll probably be ok though, as the hot side is probably quite small still meaning the turbo is shorter. The S14 turbo fits the S13 with no problem at all but as soon as you get a T3 or a T34 on there you need to get hacking. :)
Well I think these are SE's T28 hybrids but I'm not certain how they were put together.
Looks like i've even more work to look forward to :rolleyes:
For sure Ian will have to modify his engine mounts.
Attached some pictures of his turbos and Pentroof manifolds mounted on
my engine.
my engine.
what are you doing with mac's turbos???? :eek: :eek: :eek:
:D
I WANT SOME REAALY NICE SHINY MANIFOLDS AND TURBOS!!!!! :cry:
:D
It was Peter that got me them from Japan;)
Good morning Ian,
Can you give me the diameter of your new urethane motor mounts ?
Peter
Afternoon Peter,these are the mount's I will get back to you on the size;)
Here's a pic of them fitted:
Might be worth mailing SPL Parts or Z1 Motorsport and asking them.
That's close :eek: however they do look smaller than the stock ones :dance:
You're all crazy mothers!
but I like it!
