Oil temperature gauge fitting
I getting progress to tap into the sump so I can fit an oil temperature gauge.
I think most of these type gauges all use the same fitting? can someone confirm what type and where I might get one asap.
Steve E :duffer:
Most likely to be 1/8BSP fitting. Tried the traders on this site?
Steve E :duffer:
Didnt ur guage come with a sensor and a fitting?
another nice solution, so you won't have to start drilling holes in the sump:
"The billet aluminum oil sandwich adapter is installed above the oil filter, and makes it easy to install aftermarket oil temp/pressure sensors (2 1/8 PT ports and 1 12mm port). Even comes with installation tools. Lowers oil filter by 27mm."
http://splparts.com
http://splparts.com
Hi buddy,
Have you actualy used one of these or have you just found it when browsing?? Looks an interesting solution. Infact has anyone used one here?
cheers Jonce
[sIGPIC][/sIGPIC]
Hi buddy,
cheers Jonce
Have thought about this one but as you say,anyone got one,i have a sump temp sender ,and would now like to sort out the aftermarket pressure gauge but allways putting it of :rolleyes:
I bought a oil pressure guage off of Chris but didn't realise it came without a sensor adaptor. Chris supplied me with a greddy oil temp adaptor which was really good. I even managed to get the oil temperature guage sensor fitted into it.
It does look like a good idea, though I think it would depend on the shape of the sensor you use. I only say this as I tried to connect my oil pressure sender in the US location above the oil filter and it fouled the steering U/J.
Put it all together again and I couldn't steer - seriously unimpressed!
