By the looks of my air con rad its nackered I was going to remove it! is it just a case of disconecting it jobs done?? I want to keep the heating side but not worried about the air con its self
:confused: If im right in thinking you cant just lift it out it has to come throught the front?? so this means off with the bumper..:( But im sure if i am wrong someone will jump in and give me a :slap: :x:
im taking the bumper off, think its easyer to get to the pipes but I think the coolant rads got to come out to get it out not sure what to do with the pipes left though
I'ts a long time since I removed mine but I definately didn't need to take the bumper off. If you haven't already done it, remove the pump as well and the engine will rev easier and you'll see a small improvement in mpg. Also, it weighs a ton!
Spot on you just undo the main water rad and the AC one slips out , well worth removing the compressor as Dick says make a little difference, not an easy job to remove all the associated pipework though , just hassle really
Ryan
will I still have the heating side though ?
thanks for your help :D
