Vibration at > 85MPH
Folks,
When I travel at over 85mph I get vibrations from the front. They affect the steering wheel and make things in my rear view mirror go fuzzy. Clearly this is not a problem on normal public roads, but I could do without this on the track.
I've recently had the prop shaft centre bearing replaced, which fixed the thrumming at 40 and 60mph through the seats, so I don't think it's that.
I had the wheels balanced about 10 months ago, but I drive over 10 million speed humps a day. Do you think it's likely to be wheel balancing, even if the vibes only become noticeable at very high speeds?
Any other thoughts?
Cheers,
Russ.
could be. I would go for the cheapest possible solution if I was you. Get all your wheels balanced and get it tracked too.
Could be buckled rims ! If your rims are second hand, or if youve kirbed one on a roundabout etc - take them to a tire fitter and get them to check the concentricity of the rim ! Its an outside guess
