Passenger side smoking, follow-up, compression results
As the US guys are very loquacious, I make a try with you .....
:D
Here is the follow-up of this long story :
Part 1 :
http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=871799
Part 2 :
http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=878788
I performed a compression test several times with ENGINE COLD, the results :
(I added half a coffee spun of oil for 2nd and 3th attempts)
#1 : 160psi > 175
#2 : 175psi > no other try (to keep it dry)
#3 : 160psi > no other try (to keep it dry)
#4 : 140psi > 155 > 170
#5 : 135psi > 145 > 155
#6 : 160psi > 175
I cannot perform it with engine warm. I removed too much stuff arounf the engine (passenger turbo, radiator, some belts ....)
#5 has definitively a problem but #4 should also whereas I had no smoke on driver side ....
I performed a leakdown test also, I just have an air compressor though.
I listen at the dipstick location, I didn't notice any difference between the differents cylinders, even the #5 didn't seem to leak more than the others. I applied 5 bars, compressor off, and it required more than 1 minute to loose 0.5 bar ... it doesn't leak so much then ....
Any advice ?
:D
Part 1 :
Part 2 :
#1 : 160psi > 175
#6 : 160psi > 175
Any advice ?
Stop using words like loquacious.
seems like #5 has valve problems as #4 has ring problems.
-Eric
Eric, (I'm the elctronic guy on ztech.net)
You say that because I managed to get 170 on #4 after having added oil 2 times and only 155 on #5 ?
I definitively have some oil residues on #5 exhaust track, what would be the link with a valve problem ?
Thanks.
*edit* scrub that lol I need to learn to read..... :slap:
indeed, that's my first impression after reading your story.
but it can also be something more serious to #5 (like a cracked piston)
-Eric
Thanks.
