Help
has anybody got a picture or something on where the standard dump valves are hidden .what does it take to remove them ,what will I have to replace :confused:
pull the headlight panel - you should be able to see them - one on each side
Thanks Adam
If you remove them what would be the thing to put it it's place ,any old pipe or what
What? you nutter! If you remove the re-circs then.......get some bov's!
Why do you want to remove them?????
Because I'am looking at replacing the with a set of aftermarket ones
??? But you said what goes in its place? You lost me!!
Ah! do you mean if you install them up on the throttle bodies then what do you do with the standard re-circs???
My HKS replaced the recircs in the same position.
James you shown read the thread a little more closly ;) remember the 1st April mate
steve thanks just what I was looking for
James the thread not happy z stolen number 42 me not read just hitting reply ;)
