SGP pulley & c/f prop installed
Very impressed with this combo, car pulls very hard and smooth from low down, engine has a slightly different note and I'd swear my exhaust has got louder :confused: :cool:
After my first trip noticed I hit 16 psi, so I've had to turn down the duty on the AVC-R to 60% from 63% to hit 1 bar - wasn't expecting that one. I'm also getting more popping than before and definately running even richer than I was to start with - roll on the tuning session at Thor :hyper:
Only problem I'm still working on is a groan from the rear end when pulling off, a slight whine when boosting at certain rpm's, and a clonk noise when coming off the gas in a high gear at low rpm.
I've got new rear wheel bearings, new poly bushes all round (including sub-frame and diff) and new prop - guess it can only be the diff itself unless people have some better suggestions.
:dance: :dance: generally though :D
James, check your engine mounts which could be the cause of the clonk.
Steve
Steve
Thanks Steve, I'll get them checked. Wasn't planning on pulling the engine anytime soon :cry:
I guess urethane ones are the way to go though if they are shot ;)
Jaffa when is the tuning session at Thor dude ??
I'm going up on the 24th to get my AFC tuned, hopefully free up a few gg's and I haven't had it dyno'd since the boost was upped
