Rain water and engines!!!
Where do i start?
Well i have been sorting out a coolant leak for a while now so the Z has been sat on our car park for a week or so.
I have removed the front bumper and headlight panel (as you might guess) However the other day/night it pished down and i had forgotten to cover up the pipes indicated! I dont know how much rain got in, but i would say a fair amount did. Does anyone know if this is going to cause me problems or is there a drainage point somewhere?
Cheers,
Pete
DONT START ME ON THIS ONE! I bent a conrod with rainwater. If i were you i'd try and drain as much out as poss.
At the place where I got my block bored, there was a con rod from a truck there about the length of your fore arm and nearly as thick bent badly in the middle. All because water got into the engine. :(
Can your hoover suck up water? If so get it down there and suck as much as you can out.
Stuart
Or a sponge on the end of a stick!
Take the pipes off that go to the recirc valves, most of it would be in there.
cheerz, mickey
