6hrs and my first problem
first time i put my foot down
the limiter kicked in at 5000rpm!!!!
oily patches under car
help
How fast was you going and be truthful ;)
Was it around the 112mph area?
Not sure, run an ecu diagnostic see what it throws you, I know if the AFM is malfunctioning you will be limited but that is to about 2.5k, 5k i'm not sure, could be other sensor that is faulty, give some more details like does it do it all the time / only in a certain gear / speed? when warm / when cold?
Then I am sure someone like duffer can give you some good advice.
cheers
the battery on the car had been disonected for a month reconnected when i picked it up this morning
drove for 2 hrs on damp roads taking it easy
roads dried
booted it in second
shock when it hit limiter at 5000rpm
went like a train to 5000 tho!!!
So it cant be the speed limter. Any ECU code? Have you done a test?
havent done a test yet just going to search to find out how to do it
thanks
Basically
Ignition on
Take up the carpet in the passenger footwell.
unbolt the wooden panel underneath.
You can see the ECU.
On the left side off the ECU there is a slot with a LED and a little screw in it.
turn the screw fully clockwise wait for 2 seconds and then turn it back. If you get it correct the LED will flash and the check engine light on the dash will flash the same.
You will have long flashes and short ones. Count the long flashes. These are your tens, so if there are 3 long flashes thats 30.
After the long flashes there will be short flashes. These are you units. So if you get 5 short flashes that is four. There will be a pause before it goes back to the tens again.
So the long 3 flashes and 5 short equals 35.
The codes are
11: crank angle sensor circuit
12*: air flow meter circuit
13*: engine coolant temp. sensor circuit
14*: vehicle speed sensor circuit
21: ignition signal circuit
26*: boost pressure sensor
31*: ECU
32*: EGR function
33*: exhaust gas sensor circuit (left)
34: detonation sensor circuit
35*: exhaust gas temp. sensor circuit
42: fuel temp. sensor circuit
43*: throttle position sensor circuit
45*: injector leak
51*: injector circuit
53*: exhaust gas sensor circuit (right)
54: signal circuit from A/T control to ECU
55: NO malfunctions in the above
You can find more detailed instructions at
http://www.ttzd.com/diagnostic.html
I had the same problem when the "black box" speedo converter on my zed went t1ts up, pulling like a train then like hitting a brick wall when the rev limit kicked in. My solution was to buy a set of uk clocks, no need for black box, have the rev limiter/ speed limiter lifted on the chip
thanks for the help
i'll be busy tomorrow trying to find out what it is
Jock i got ginga's Zed
I really felt for him when i drove off
I dont even want to think about how gutted he was, but he will be happier if it is going to someone who will look after it. Do you remember if your stearing feel changed, when the limiter cut in? It happened to me that way, everybody said it was the speed sensor (the power steering is affected by speed) but as posted above it was the box of tricks, they seem to go whenever they feel like it,, which is why I changed for the uk spec clocks
Very strange
took her out tonight
HICAS light came on for a bit then went off!
once warm she went all the way to 6000rpm !!!!
sweet as a nut. FANTASTIC!!!!!!!!
top the fluid up with Castrol TQ Dexron III
hicas light now off
still leaking tho
car goes to 6500rpm if taken there gently
if you floor it it bangs into the limiter at 5000rpm then drops to 2000rpm
turning it off then on again helps
strange
will run ecu diag at the week end
oil pressure starts at 4 when cold then drops to 2 when warm!!!
