My drivers window rattles when it's down about 1/3 way. Is there anything that can be adjusted, I'm gonna look tomorrow but just wondered if anyone else has had this problem.
Vijya
I had the same problem last year. Remove the door trim to get to the inside of the door pillar, there is a 10mm bolt that comes through the glass, on the end of that bolt there should be a 10mm nut. If the nuts not there or loose, hey presto!
looked at it today, and what it seems to be is the pin that comes through the glass has a roller on the end and that is not tight, I can't get to it, any ideas?
Vijay
You got me on that one Vijay!!!
mine had a thread so all I did was screwed a nut on the end of it and now it is perfect.
