camber adjustment
:confused: does antone know if there is a way to adjust the rear camber angle? the car has been lowered and the camber not adjusted accordingly
Yes the bolt holding the rear wishbone thing is on a cam from what i remember although not sure how much adjustment that will get you, Its in the manual anyway,
Paul
Paul
thanks for that mate. i'll look into that
jase
I just maxed out the rear adjustment with these cam bolts on the inner diff side top arm- very tight btw, and its still got some negative camber. You then need to check the rear toe in as well because it changes when you do this. My 18s always wear out on the insides first.
