took the car out earlier today and it was driving fine, took it out just now and its drivable but lumpy :cry:
-the power keeps goin up n down like something under the bonnet keeps going on and off
-th exhaust sound isnt smooth like it was befor, its more badabadabada
-when pushin (wot i think is) the thottle cable thing that controls the throttle bodies in the centre above th plenum away from me a little i can hear a hissing sound, cant really tell exactly wher its coming from
i havnt got a clue wots going on or wher to start looking
help me out guys
yaseen
sounds like a pipes split or come off. You`ll have to have a route around.
cheerz,mickey
I had same symptoms as those you describe and it was nothing more than a simple pipe split......
These 2 area's are worth checking, they could be split on the underside and you can't see it!!
My trouble was with the one on the right as you look at the picture on the fuel dampner (I'm sure it's that side...LOL) and the pipe was split and hissing and caused the Z to run REALLY lumpy!!
Changed the old naff pipes all over the engine to Smithy's silicon hoses and have had no trouble since.....:) (fooking said it now!!) ;)
Hope this helps.....;)
I would advise you to contact Smithy and buy some silicon hose to replace all the old stuff that's under there, prevention is better than cure!! :)
Matty.
Had similar symptoms on mine, it was the
wires going to the injectors, try waggling them
(gently!!) see if it makes any difference, same
with the coil packs.....Just a thought!
UPDATE
just before i went to work i took the car around the block again with both windows down just to make sure and its definately an air leek, the hissing is pretty loud cos i can here it above my exhaust.
another thing iv noticed is its idleing realy bad, drops really low before searching and finally finding approx 700rpm, i can feel a lot more vibration thru whole car as well
i havent got a clue which hoses it could possibly be so i dont even know where to start
whats the best way of detecting which hose it is?
thanx guys
help me out guys cos i wanna try and get it sorted by this wknd so i can go to the midlands meet!
well i just had a snoop around the bay while im waiting for the experts to reply and i am honestly lost, it sounds as though the hissing could be coming from absolutely anywhere and all my pipes are black and look the same so i dont know whats what.
when pushing on those wires very slightly i can definately hear a hising sound coming from near the passenger side throttle body, when i rev the car (which am pretty sure isnt doing th engine too good) as the revs drop back down to idle there is a louder hissing noise coming from somewhere else in the bay
Did you take off the passanger side throttle body pipe to check if it's split on the underside???
Matty.
Hi mate. if you can get it to the leicester meeting point for the convoy for about 10:30 I'll have a look for you and see if we can sort it.
There's a small vac line that attaches under the main boost hose on the passenger throttle body - check thats on ok.
sorry for being such a pain but have you got a pic andy?
cheers stuart, il try and get there if i can, as long as th problem dsnt get worse cos it was driving really bad when i took it round the block yesterday
You *star* Mike :D I haven't :D
I photographed every little bit when I had it in pieces. It makes a great reference when you can't quite reach something or work out where something goes.
I obviously work on far too many of these pieces of shit :rolleyes: :D
I have...
Mike are your pics available for general viewing or do you have them hidden away?
cheers mike, will have a look tomorrow morning, u wdnt have a pic that shows me all th possible pipes that i need to check do you?
Yaseen, im no zed mechanic but ive had my head under my bonnet for more time than i care to remember, im only working till about 10am tommorrow and covs not far from leicesterso if you want me to have a look give me a bell, two heads have got to be better than one!!
My number is 07966 891954
well with great thanx to barks who came over this morning i have finally found it was a hose that had slipped off, the one in mikes pic actually. idle is still a bit rough but at least th cars running properly!
cheers everyone for your help, c u on saturday stu
Nice one Yas, Glad it's sorted.
Top bloke aswell to Berks:D
Hopefully see you on Sat.
Rich:D
LOL I'm gonna have a lovely collection of prizes from the forum then :D
