t p s
been testing two different tps's
the one off my car and one i was lent
neither of them will read above 3.2 with
throttle completely released not the 4
that is stated does this mean that they are
both faulty and need to buy a new one???????
steve
what's the reading at idle ?
it should be around 0.4 - 0.44
I remeber someone else having this problem. he could get 0.4 at idle but on 3.8 at FT.
Mmmm
dont think ive been testing right
ill have another look tomorow
the weather might be a bit better
steve
What exactly does the throttle position switch do anyway?
It measures the, er, throttle position, mainly so the ECU knows what you're asking the car to do and can inject through the injectors as required!
There's no carb remember...
Hence if it's misadjusted you might floor it and it'll think you meant 50%, or you might not touch the throttle and it'll take you straight over the stop line when you put it in gear. THis is why it's vital to the whole thing, especially in an auto, because an auto needs to know what you meant to pick the right gear.
Even worse in the daily driver, because in that one there's no throttle cable at all, just a TPS on the actual pedal! (BMWs are the same I think)
right i set the tps properly now
on idle its 0.42
and full throtle its 3.9
so that all seems fine
the tickover was at 2000rpm
so i turned the css a little which put it back to about 900rpm
the car changes gear much smoother now
but still revs out in first when going from stand still
any other ideas
thanks
steve
Hi Steve,
Did you mean you turned the CAS? if so that would change your timing, that needs to be spot on.............
Vijay
yes thats the thingy
how easy is it to set properly
and how else can you get the tickover down
would the cas setting effect the gear change ?
sorry for all the questions
thanks
steve
your gonna have to get a timing light to set that back correctly. Have you cleaned the throttle bodies (and IACV valve) and all connectors, then reset the ECU? That's what I would do and then you can adjust the idle if need be :)
Vijay
ok mate will give that ago
ive been looking at the rides section
must admit your car looks sweet mate
steve
Revs out in first ?
what does that mean mate ?.
Hi Revs at idle could be due to a boost leak. Have a listen around the engine for hissing.
its auto and wont change from first to second at high revs (will rev to about 7200)
will change when you ease off slightly
every other gear change is ok
steve
Vijay
hi vijay
thanks for your reply
ive done a search but cant find what the
iacv valve is or where it is
steve
it controls the idle (base). It's at the back of then engine near the battery. You'll see a thick rubber 90 degree bent pipe. Remove the end and spray carb cleaner down it (after you've done the throttle bodies).
OUCH!!! Get that timing set back to 15deg btdc RAPID!!!!! Its VITAL that the ignition timing is set correctly on these cars....
I'd get someone to give you a hand if I were you ;)
CheerZ,
Andy
ok will do mate
steve
oh yes, I was driving around with the timing off (still don't know how) and I had huge detting, enormous backfires and general lumpy burbling noises. Had it reset and it's run very nicely ever since.
Thankyou very much
