Fuse Box
Am not getting any power to my LHS Headlight fuse. Can the individual section with Horn, RHS, and LHS Headlight be pulled from the front of the fuse box? Have tried taking out the white slidy thing , pulled back the clip, but it won't budge.
How are the wires attached at the back? I'm worried it I pull to hard I'll feck it up.
Cheers,
Matt.
You need to remove loads of the trim down there to get the fuse holder out, as a tempory solution you could run a wire from one of the other fuses to the duff one that should work as a semi permanent fix.
Best of Luck.
Hi mate - it was the one in the engine compartment, but soon realised the holders come out the BACK of the plastic frame :rolleyes:
Found the easiest thing to do is undo all the clips and slide the plastic thing off the front.
Cheerz,
Matt.
