`Heater Matrix
First I would like to thank Ryan for helping me change this.
I am past the halfway stage!
Last night I connected the two metal pipes to the matrix, warmed up the engine let it run for 15mins NO LEAKS!! :)
I removed the dashboard for this & there are two screws that are impossible to see if you attempt to change the matrix without removing the dash.
One screw on the top matrix pipe. The other is the top screw that holds the plastic side cover to the matix, its at the back, right up at the top and its in a recess, there are 5 screws that hold the plastic cover in place,4 you can see.
All I have to do now is put everything else back! Dashboard, plastic heater pipes,dial cluster, all clip sensors,all conecters for the cluster, glove box, cd & radio, centre console!
Oh & things I took off for no need, heater fan, cover of air con & loads of clips all on the passengers side! FFS is it all going back?
Well Ryans says it will!! :bow:
Arthur
No posts to show
