Bored at work????.....
......then why not waste a few hours here;
MOTAS
Warning, can be very addictive and waste lots of your company's time!! :nono:
  • Replies 56
  • Views 2.1k
will do if i can just get past these fkin lines, what am i supposed to be lining up exactly?
You can just see a line on the right and left edges. Line the stones up to create a path for "something" to go across.
yep just worked it out
Bah, finally did it, and it took me ages!!
right then, just started playing this again, level 9, how do you get the pc to open the door?
Have you typed in the word you get given? (cant remember where u find it, in the locker i think, it's quest by the way)
put in the floppy, and u may need to reset.
Enter "quest"
u have a picture of the first room with 2 letters.
Click the door, and u get 2 or 3 letters from the next room.
Jumble these letters to make a word.
Reset.
Enter that word.
For me it was something like "A , R" and "T , E , G"
which makes great.
Enter "quest"
Reset.
Enter that word.
which makes great.
Yep that's right, type in quest to get the 5 letters, which you need to rearrange. This changes for every game so you have to work out your own word. Mine was Dwarf.
Oh, wait until you get to the 'Green Wall' it's a beeeeatch!!!
ok am stuck in the fireplace room, have cut the triangle with thelaser put it in the security panel panel is active but door still locked aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhh!!! :mad: :mad:
put it in the panel a different way.
cheerz, mickey
stuck on level 12.....how do you unlock the force field for the door? i have the code but cant enter it.....
cheerz, mickey
cheerz, mickey
Which one?
Have you got thru that ******* green wall?
i cant do that wall, is pssin me right off
what do i do with the clock weights on lev 8? tried the pedestal but cant put em down!!!!!!
what do i do with the tiles in the glass box. i've got the head running all over it but that's all it does
jase
Clock weights go in the room on the far right - they release the Knight chess part... and the tiles in the box - you need the heads to run from right to left. I can tell you the secret to the green wall (but then I'd have to kill you). Failing that heavy moderation would make me stop....
PS. Finished it in a slightly less than a couple of hours but I've got time on my hands these days.
Right now this is gunna be hard to explain:-
click where i have put the o's:
,o,,,oo,,,o,
,,,o,oo,o,,,
o,,,o,,o,,,o
,,oo,oo,oo,,
,,oo,oo,oo,,
o,,,o,,o,,,o
,,oo,oo,oo,,
,,oo,oo,oo,,
o,,,o,,o,,,o
,,,o,oo,o,,,
,o,,,oo,,,o,
Hey presto!
Got to say, that wall is the gayest thing ever.
wtf is up with the puzzle with the 2 guys? have solved it but cant get to the safe now!!!!
once you got all the colours lined up, just click something round there ( cant remember what :rolleyes: ) and they lift the puzzle back up revealing the safe...u should be able to get in.
Sounds like alot of stress to me guys, thats why after 5 minutes I quit i've got other S**T on my plate to sort out like workin' on my Z. :)
Which one?
yeh done the wall.(was a bitch) bit further on. done the laser walls but cant find out how you deactivate the force field. Got the key to the door just cant get to it.
Nismo, you *******. :D :D
cheerz, mickey
MickyB - use the spare bulb to replace the light bulb in the angle-poise lamp, then turn it on and move ti up and down. You get given a key, 1231123E I think, this drops the force field. Then it is finally over!
Yee-ha, finally done it. Wasted some time too. Anymore? :hyper: :hyper:
i think its in the the light, in the same room as the sidelight were the code is, remove the fold in the rug and then slide the chair over. the key should then be in the light fitting.
