Yay yay yay
I've found my problem!!!!! It was the coil pack on the drivers side rear. Swapped a couple of coils around and I pulled the plug off the coil I thought was faulty and it didn't make a difference to the revs. Also I found that one of the other side cylinders wasn't firing so I whipped out the coil pack (which was the centre one) and swapped it with the fron one and noticed that there was a lot of corrision in the bottom of the middle (faulty) spark plug bore. And this was the problem (I think) on that side.
Now what would be causing this corrosion? (Dont say water :D ) Do you think that the coil pack was leaking?
Thanks to all of you guy's for the excleelnt advise that ultimatly got this problem solved! :dance: :dance: :dance: :cool: :cool: :dance: :hyper: :hyper:
No posts to show
