- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I removed the passenger turbo because I got tons of white smoke at idle (oil burnt smell).
What I discovered doesn't make me happy, the exhaust track is completely fully covered with oil cooked, that's not the rear turbo seal which leaks (perhaps it leaks also) but the oil comes from the cylinders !!
I haven't removed the exhaust manifold yet (full of oil cooked).
On the pics, don't take care of the oily crap outside of the turbo, it's ATF fluid residue, a power steering problem solved.
Last time I removed all the spark plugs, the left and right ones didn't look different but all were covered with oil deposit.
Only the passenger tail pipe smoked like the hell at idle (no H pipe). I changed the PCVs 2 months ago, the old ones were st
uck.
BUT I ran the car a lot of time at idle the last 8 months because the car stands in my garage and I had several others troubles to solve, then it means the amount of oil sucked could be higher than normal driving. The back of the plenum had oil as a lot of Zs (on each side).
I put new spark plugs 2 months ago, I will check if one is more oily than the others to identify cylinder failure.
Can it be the driver side front turbo seal which leaks oil, the oil is sucked by combustion chamber and cooks the passenger exhaust manifold ??
Last time I checked, I had no blowby gas (through oil cap), then it cannot be valves stem seals. It may be worn rings ..... I didn't performed a compression test, and cannot do it now (a lot of stuff removed)
In fact I bought the car last August and when I got it, there was no smoke. Since September, I didn't drive the car, I fixed some other problems (power steering rack leaking ...), the car stands in my garage but I ran it a lot at idle (I consumed almost one full tank at idle !) to diagnose it with consult and so on and to try to be sure about the source of the smoke.
One time, when I accelerated gently from idle, my ear on the engine, I heard a slight scraping noise around the battery, I thought it was a turbo wheel scraping the housing.
Now, I can tell the turbo wheel doesn't touch the housing but there's some axial play, I can feel it with my fingers.
