soft whirring....
... or buzzing sound coming from rear of the car all the time, is that normal? note or volume never changes
yas
Could be the fuel pump.
Can you hear it with just the ignition on or do you have to have it running to hear it?
Si
cant remember, il have to check when i take it out later, could it be anythin els?
Circulation fan in the middle of the T bar?
cheerz, mickey
i hear it for about two seconds when i turn ignition half-way, then it stops. sounds like fuel pump but dont know why it'd keep going.
when you turn on your ignition the fuel pump will pump untill the fuel rail is up to pressure thats why it only comes on for about 2 seconds. then as soon as the car is started the pump will run until the ignition is turned off
yeh that happens but thats a much louder sound, after that you can here a very soft whirring which is ther all th time, u only here it if ur listening out for it
Fuel pump isn't it. Don't you hear it changing in pressure as you Accelerate?
the only thing i hear when i accellerate is th engine and exhaust lol n when i boot it i hear a whoosh which iv always assumed is th turbos (hope im right)
