Hi,
I have got an oil cooler which I believe is the same as the one luke at the zedcentre sells!
The only problem is the fittings to connect it to the oil hoses are too big any idea where I might get some smaller fittings from?
Mark,
Try deemon tweeks, they sell all sorts of pipe fittings and things.
Either them or think automotive / james lister.
try Pirteck hydrolics
leyton 020 8556 9500
park royal 020 8961 0333
either will give you the closet branch, good for getting hyd. hoses made to patten.
Cheers guys,
I don't want to change the hoses Russ as they have other fittings to connect to the other end, they also contain a restrictor in line that is important.
they will swage just the ends on if that is all that is required save on adapters and should be cheaper
RS (radio spares) do a good selection of pipe fittings
