Creaking Front Brakes
Could anyone give me some idea why my front brakes creak like made when i apply them when im stationary?? about to have a look this week and just wondering if anyone can help..
cheers
johno :confused:
[sIGPIC][/sIGPIC]
like mad that is. not made
[sIGPIC][/sIGPIC]
Mine used to, and I dont see how but they dont anymore since I changed the front tie bar bushes...???
Ive never heard of that before. Creaking when stationary!
Its deffo not the pedal?
Can only think of knakered pistons in the calipers , loose calipers, grit between piston and pad, how can the front tie bar bushes cause it? im not saying they dont tho.
Interesting to see the replys to this Q :-)
trev, I ment when i depress the brake when the car is stationary. e.g when parked via the hand brake and then press the brake pedal
[sIGPIC][/sIGPIC]
hi,
When you mention the tie bar bushes do you mean the tension rod bushes. Are they the same thing or am i barking up the wrong tree. I know my tension rod bushes are knacked because when i lifted the car the other week i noticed them.
[sIGPIC][/sIGPIC]
Yes, sorry, wrong use of name etc.
Let me say I dont see how this could make any difference, (changing these bushes for poly ones) BUT, it did????
could be siezed pistons. you can get rebuild kits which arnt too expensive if ness.
take the pads out & get someone to carefully press the pedal down, jam up any pistons that move & see how hard it is to push the others out.
mine had 2 siezed pistons on both calipers
Hi Jonce
had exactly the same problem,the pistons tend to move further when the pads are low that's what's creaking,put new pads in and it will stop guarunteed!!!!
Hi Jonce
what sort of pads do you recommend :dance:
[sIGPIC][/sIGPIC]
Jonce
Are you sure it's not the bulkhead creaking when it flexes as you apply pressure to the pedal ?
Mark
Jonce
Mark
is this a common??? never heard of it before. The creak comes from both sides
cheers johno
[sIGPIC][/sIGPIC]
I think it is pretty common.
I'v ejust fitted a new brace for the master cylinder to eliminate flexing and the creaking has gone.
Mark
Try the pads first you should change them after a while anyway,not sure which ones to reccomend though i need new ones my ones are squealing !!!!
