Suspension bushes!
Both front tiebar bushes are coming close to needing replacing so have decided to go the whole hog and replace all the bushes front and rear. Obviously i am wondering whether to upgrade to polybushes or stick to standard ones?
Will also be doing a full suspension change at same time so consider that too.
Links to sites also appreciated
I'd go for the full Energy Suspension poly bush kit.
It does make a huge difference, particularly the rear subframe mounts.
Only thing to bear in mind is it's a big job to fit them. Front ones are pretty easy, it's the rears that take all the time.
Allow a full day if you have access to a 2 post ramp and press. It means dropping and dissasembling the whole thing to fit them.
Agree with John, just had mine done as my subframe bushes were leaking, so I had Poly bushes all round and they make a huge difference, car feels a lot lighter, with only a slightly firmer ride. You do get to here the diff whine a bit more though.
You're not kidding, if you've got a plate diff like mine the whole car vibrates when you slip a wheel!
Most improved thing IMO is traction. Much less wheel hop / tramp.
I've got a set of 4 brand new Energy Suspension rear subframe bushes for sale if anyone want them? :)
Pete
Thanks all.
Any ideas as to where i can buy a full set of polys. Gonna do front and rear courtesy of a friend whos a mechanic and has access to a full workship at a dealership(unfortunately not nissan). Charges me very little too and will do weekends and evenings.
or Mike Feeny, or through Courtesey Nissan
Mike feeny ?
Cheers ill get to know who everybody is eventually
Spoke to Shrimpy the other day about his ones he got for sale ....:D can anyone answer the question i posed to Pete will the bushies for a 2+2 fit a SWB...??
got to ask these questions.... :)
Pete
Cheers . The ones you have are they for a UK spec 2+2. If so what you looking for ?
Yeah they'll go on a UK 2+2...dropped to £60 :)
