T-top gutter drain holes
Those big (approx 1/4" dia) drain holes in the t-top gutter, where do they drain to? I tried to see if they are blocked by putting a small dia. wire down, but the wire dead ends within about an inch? Do they turn sideways?
John
Not sure where they go but i used the flexible stuff the wife uses to hang net curtains at the windows to clear my drain holes on my celica, it might work on these as well.
Thanks,
I just tried pouring water down them.......they drain ok, I guess my rubber seals are fooked
John
The water comes out at the bottom of the rear sill. One of the main reasons the sills rot is due to the drain holes being blocked or the hose is split.
I dont know , only checked the front one. I have temporarily gunked up my t-tops with silicone sealant untill I can get a new rubber seal.
John
John
If you remove the trim on the A-pillar (next to the windscreen) you'll find a plastic tube from the front drain hole. If you remove the trim from the B pillar (behind the seatbelt mechanism on a UK model Z) you'll find another drain tube.
Simon.
