Actuator vacuum hose resiting??
At the moment the actuators pick up from halfway down the boost pipe!
I have got rid of the aiv/egr system that picks up from by the throttle body, and was thinking of resiting the actuator pick up to the throttle body to make it slightly more responsive!
Any thoughts?
Mark,
Is that line still on the upstream (ie not manifold) side of the throttle? From memory, isn't it also a very small diameter port into the body its self?
Most systems run straight off the compressor outlet, you could always do that.
Yes it is a small diameter port and it is still upstream of the manifold!
Don't see any reason not to do it if its neater, but I don't think you'll gain anything.
The pressure the actuators see will still be governed by the boost controller anyway so even if it is slightly lower at the TB due to pressure drop through the intake pipes it shouldn't make too much difference.
