How does my heater / air con work?
I've only had the car about a week.
I understand the heater except the 'auto' button.
Also how can you tell if the air con is on or off? I guess it's off now cos it's cold but is there any way I can tell in summer or stop it soming on to preserve power / fuel?
auto = A/C on
Hi Craig,
Didn't you get the manual, mate?
Auto = everything including a/c on. Electronics regulate temp to your setting and direction of airflow.
Econ = eveything EXCEPT a/c on, otherwise same as above (cheaper to run in winter without the a/c)
REC = recirculated air inside car. Doesn't draw in fresh air and only works with a/c on (auto position)
OFF = pretty obvious ;) everything switched off.....
Richard :smw:
Excellent; thanks again.
Yes, auto it had to be. The newest manual i could find was about £3k more and two years older.
